Page 2 of 2
Re: PIWIS Coding done today!!
Posted: Fri Apr 14, 2023 4:46 pm
by 718socal
Tom wrote: Fri Apr 14, 2023 3:50 pm That is awesome! Curious if it can remember the last mode too? In other words, if the car is turned off when in Sport Mode, can you make remember that for the next time you start it up?
Not Sport Mode. Only PASM and ASS. You need the T-Design module to remember the Sport Chrono knob and Exhaust settings.
Posted: Fri Apr 14, 2023 5:00 pm
by Arne2
718socal wrote: Fri Apr 14, 2023 4:46 pm Not Sport Mode. Only PASM and ASS. You need the T-Design module to remember the Sport Chrono knob and Exhaust settings.
Does T-Design have a single module that does both now? Last time I looked there were separate modules, one for console buttons and a different module for the steering column functions.
Posted: Fri Apr 14, 2023 5:13 pm
by 718socal
Arne2 wrote: Fri Apr 14, 2023 5:00 pm
No they have one for each. The Center Console and the Sport Chrono knob. I bought those two and sold them after I got my PIWIS working.
Posted: Sat Apr 15, 2023 2:12 pm
by Stormy_Monday
Arne2 wrote: Fri Apr 14, 2023 3:20 pm
blueline wrote: Fri Apr 14, 2023 1:59 pm Question Larry - after Navigation is activated is there a way to update maps without a subscription?
Yes, my Nav is self-activated with the SD card method, and I've updated the maps twice. The biggest issue with updating the maps is the download time.
please explain this for those of that are slow....
Posted: Sat Apr 22, 2023 11:51 am
by Arne2
Stormy_Monday wrote: Sat Apr 15, 2023 2:12 pm
Arne2 wrote: Fri Apr 14, 2023 3:20 pm Yes, my Nav is self-activated with the SD card method, and I've updated the maps twice. The biggest issue with updating the maps is the download time.
Detailed instructions are here.
https://github.com/harman-f/MHI2_MIB2_A ... stallation
Summary:
Download the installer AIO package (Download Manager recommended)
Extract files to an SD card
Insert SD card into slot SD1, installer will run.
Can take up to 40 minutes with the ignition on, so having a battery charger connected is highly recommended.
Installer will update PCM firmware, enable wired CarPlay and Android Auto, and enable Navigation.
Navigation does require a GPS antenna. Some cars will have one, others won't. It appears that if your car came with Porsche Connect (as mine did), a GPS antenna is part of that. If you don't have an antenna, one can be added.
The Navigation maps will date from the build date of your car, so if your car is older than a year or two, you will want to update the maps as well, which is a separate operation.
Both the NAV and MAP buttons on the PCM will then work. You will not be able to show Nav or Maps in the right side of the gauge cluster, but all else is like factory. (Activating the cluster requires PIWIS or other coding, and a new data cable from the PCM to the cluster. Some early models—2017-18 in particular—do not have the connector port on the cluster for the data cable, so check that prior to buying the cable.)
Posted: Thu May 04, 2023 6:15 pm
by Tom78737
T-Design (www.t-design9.com/) sells a Memory Module that remembers your button (or mode knob) settings. It mounts easily within the console and works like a charm.
