Note right up front that this is a question about your favorite tire CLEANER, not at all related to anyone's favorite Tire Dressing or Coating.
Background--
New tires on the front forced me to do some matching wheel cleaning and detailing for the rears on my 928. I've bounced between a few different tire cleaners over the years, with most still leaving a brown film /stain on the rubber even after multiple spray-scrub-rinse cycles. My latest try is Meguiars Non-Acid Wheel and Tire Cleaner, which does a great job on the wheels but still leaves staining on the rubber. I've resorted to multiple scrub and wipes with rubbing alcohol to get more of the brown out, but even that never gets those rubber things to actually clean and natural black.
I'm not at all a fan of the glossy black treatments that many seem to apply. I'm to the point of using a Meguiars aerosol on a dedicated sponge just to even out the color some, but it still isn't a natural black. Looks like a cheap detailer's paint job even with the light indirect coating and follow-up buffing with a towel.
So --
Got a favorite tire/rubber cleaner treatment and protocol that lifts all the brown out? I appreciate your thoughts and experience.
Detailing -- Favorite Tire Cleaner?
- Has thanked: 265 times
- Been thanked: 259 times
SoCal 928 Group Cofounder
Without doubt my go too (and nothing comes close in my opinion) is YUM undress. This stuff cleans rubber like no other. I always use YUM dress after. This soaks deep into the rubber and can be built up as required. I usually use two applications maximum and it leaves the tyre in a new condition. Nice matte looking and not like the standard glossy wet look.
https://yumcars.co.uk/product/yum-undress/
https://thehouseofrags.com/products/yum ... MdjcyPSk-n
Thanks for the recommendation and the links --
The YUM product looks great, but limited availability in the US is a challenge. Guessing it's related to some moronic (tm) tariff issues. Plus, looking at the MSDS, it uses sodium hydroxide. Great for cleaning rubber, but a nightmare on aluminum wheel and suspension bits. Have you seen any dark grey hydroxide reactions from aluminum stuff?
For those playing along at home, my 928 came with anodized aluminum disk wheels, and they are incredibly sensitive to chemical cleaners that stray much from neutral 7.something pH. The caustic stuff like sodium hydroxide makes short work of oil and grease residue and contaminants, but has a bad reaction product when used on aluminum, even anodized surfaces like the 928 'manhole cover' or club sport wheels. Even momentary contact on the anodized surfaces causes a reaction stain that's virtually impossible to fix with polishing. I have the carefully-preserved original wheels, and run a set of painted/coated wheels for daily driving. A posting a few years ago added a set of those same disk wheel with chrome added. So still sensitive to using anything that isn't neutral pH. Always fun! The DD wheels are painted aluminum takeoffs from an early 2000's C2 narrow-body. There's some tolerance for some treatments so long as they don't affect the nearby metal bits like suspension and brake bits.
gzxfia
- Has thanked: 31 times
- Been thanked: 22 times
I was doing some research on this recently too.
I had been using Adam's Wheel and Tire and never realized how alkaline they are and definitely not good to use for every wash (at least for wheels) after watching some youtube vids. On tires it absolutely cleans up the browning but that's not a surprise being pH 13.5
I'm reading good things about Armour Detail Supply Tire and Wheel cleaner (pH neutral and excellent smelling), might try them out.
Thanks for the suggestion.
A look at the manufacturer's MSDS shows pH= 13-14
https://cdn.shopify.com/s/files/1/0555/ ... 1782822216
While out shopping for other things yesterday, I browsed tire cleaners on the shelf. Bleche White was a longtime go-to when we had steel wheels and hubcaps, and white-wall tires. pH= 13
Most of the tire cleaner products I see are seriously caustic. Even regular Simple Green is discouraged for contact with aluminum. I do have some of the industrial version that's identical to their aircraft-safe product. Need to do some more research on that. I have two new tires (and wheels) to prep, so have demo candidates available if the cleaner passes a simple pH test. I'll report back on the results.
Else it stays rubbing alcohol, the small scrub brush, and half a gallon of elbow grease for each tire I guess.
gzxfia
Ah! Good catch. Looks like only the ADS Wheel cleaner is pH neutral, doh.
Though I think it is still one of the rare wheel cleaner products that is pH neutral.
https://cdn.shopify.com/s/files/1/0555/ ... 1681266278
While trying to use up the rest of my Adam's I was wondering how I can still use it on tires without it dripping on the wheels and to my surprise no one really talks about spillage from tire cleaners onto the wheels, only to not spray it directly on wheels
Probably one of the main reasons why most dedicated tire cleaners are made highly alkaline.
I'm sure you could use ADS Wheel cleaner on tires too, but might take multiple passes.
Same with using a pH neutral all purpose cleaner I'd imagine.
Does ceramic coating work to some degree as a barrier for aluminum?
