So tired of the power steering system
944_Tom
Been thanked: 5 times
Don't get me wrong, when it works, it works well. And I enjoy having power steering. But the system on the 944 seems like such an afterthought. Countless turnbuckles broken, welded, rewelded; countless v belts; pump refurb, new mounting kit and now this! The mounting point on the engine block is just gone! I think I'm going to go manual just to avoid the break-downs.
Does anyone have a reliable source for the factory (not converted power) steering rack?
Gaspowered
Has thanked: 298 times
Been thanked: 84 times
Hi Tom,
I know you asked for factory, but you might check out this video by NC944er.
He pretty much uses VW parts that bolt into place.
Edit:
It's a kit mainly comprised of VW parts that's made by this gentleman.
https://mwthemachineshop.com/steering-solutions
Brian
'88 944 Turbo S / Silber Rosa
944_Tom
Gaspowered wrote: Tue Jan 28, 2025 6:38 pm Hi Tom,
Thanks, I will check it out!
dme
Been thanked: 4 times
That looks very tempting. One of the first things I had to do (on this 951) was replace the steering rack which leaked horribly. Three years later and after the warranty has run out, it has started to weep on the passenger side. Having one less fluid to leak sounds great. Replacing the rack one last time sounds even better. Not a fun project I want to do every few years.
cp99
Has thanked: 4 times
Been thanked: 22 times
What about using an electric pump, which gets rid of the belt-driven pump? Retain hydraulic power steering while reducing a load on the motor.
Boston-area, MA
dme
cp99 wrote: Thu Jan 30, 2025 11:54 am What about using an electric pump, which gets rid of the belt-driven pump? Retain hydraulic power steering while reducing a load on the motor.
that power to run that pump has to come from somewhere. Either directly from the engine via belt or go from the engine to the alternator to the pump. Personally, I've never had a problem with the pump, just the rack and/or hoses.
944year83
Has thanked: 28 times
Yo puse una conversión a dirección manual y fuera problemas y perdidas de aceite cero
Thank you. :wave:
spacecad3t
Has thanked: 89 times
Been thanked: 72 times
Edit:
I have this kit installed, its very high quality, and I would recommend it.
