Wiring Diagram for '86 951 Idle Control Valve
RZwetzig
What are the 3 small terminals in the Idle Control/Stabilizer Valve connected to?
Thank you!
Randy Zwetzig
Fort Collins, CO
1986 951
2016 Cayenne Turbo
Been thanked: 4078 times
RZwetzig wrote: Tue Nov 18, 2025 7:37 pm What are the 3 small terminals in the Idle Control/Stabilizer Valve connected to?
Thank you!
The outer pins go to 33 and 34 in the DME connector. The center pin goes to battery voltage. Having an issue?
Evan
Has thanked: 10 times
Been thanked: 20 times
Thank you!
The three small terminals are for the two windings of the stepper motor and a common power feed.
The DME controls the motor by pulsing the ground paths for the two windings to move the valve in or out.
