I have been discussing my build in another thread, but this part needs its own.
I have recently pulled the engine from my 87 944s rally car, and was thinking to build a second motor while my longer, bigger build goes on - so I was curious on what the group thinks I could get away with reuseing for a short lived (year or so) stock rebuild... and what to toss out. I have my opinions but this is my first build of any m44 so I'm not an expert.
I'm also turning this into two builds, in a way.
Because I don't want to miss a season of events, the plans are to actually take my stock reciprocating parts and put them in another block with fresh wear parts, put it back in with the current head (which was rebuilt 10 years ago) and then take my time building quite a hot m44.40 with the original block. (I don't really care if the build uses the original block, this is more about not wasting perfectly good parts if I can avoid it).
So, I'm seeking advice on the wear and tear you see below, in two contexts.
The first question is - should I bother refinishing this block (convert to nikasil) for the a big build. I think it's fine, but want second opinions.
the second question is - any concerns seen by the experts if I was to reuse the pistons, rods and crank in a new block, and are there any gotchas or issues in putting 16v S bits into a different 2.5 block, either 8v or turbo whatever I can get my hands on here.
I did take quite a lot of pictures, so enjoy the thread and I look forward to any experienced advice here
This is the main reason i'm after advice. Cylinder #1 has a barcode ... it's the only cylinder with this. I'm not really sure if this is a common way to fail for these bores, I don't recall anyone mentioning it before. It's odd because it's not aligned with the thrust surface so I do wonder about potential crank play having caused this... but then why only Cyl #1?
The rest look like this, immaculate.
Oil pan had remnants of the oil pickup seal in it
swollen seal starting to disintigrate
The #2 rod journal does have some light lines on it. Enough to catch with a fingernail, but I think this will polish out easily.
Another view of the #2 surface
the rest looked good to me
two of the rod bearings looked like this but two of them...
looked like this.
rod bearing cap for 2
cap 1
cap 3
cap 4
Piston skirt for cylinder 1 has some gouges for sure. Not sure if this is going to be a big problem to reuse for the second engine or not, as it does only go up to the halfway mark or so. Thoughts?
Annoyingly someone replaced an oil pump bolt with a non-oem quality bolt at some point, it rusted to all hell and broke off. Got the rest out without damage to the block thankfully.
Farther away view of the bores
the bastard cylinder
Finally, as a thank you for reading this far - a picture of the car ripping backroads with another *fairly quick* Porsche in the background
