Rear Trunk Liner
Has thanked: 4436 times
Been thanked: 2411 times
FLCAYMAN wrote: Sun Feb 19, 2023 6:47 pm
Larry C wrote: Thu Feb 16, 2023 12:27 pm I bought the Cayman OEM rear trunk liner from Suncoast. At first it fit like a glove. After a year of ownership, the vertical lip around the entire perimeter is badly warped. It now looks like an inexpensive aftermarket liner. Has anyone else had this problem? What are you all using for rear trunk liners?
Yep, mine is exactly as you describe after 19 months.
Curious how yours compares to mine pictured above. The lip on mine is not perfect but it doesn't look bad to me, especially considering that the space gets used quite a bit and that it's 2-1/4 years old. My liner is from Porsche (dealer) but I am assuming it is identical to the ones mentioned that are from Suncoast.
If others here (you and Larry) have pictures that you can post, it would help to see how they compare.
Been thanked: 667 times
My Weathertech Frunk liner was installed at the same time as the OEM rear liner. The rear liner is badly warped around the entire periphery while the Weathertech one looks like the day I purchased it. The OEM vertical lips are thinner and flimsier than the one from Weathertech.
Unfortunately, Weathertech doesn’t make a rear liner. Last week I ordered a flat, water resistant rear liner from Lloyd’s. As soon as I get it, the OEM one goes in the trash.
Larry C wrote: Mon Feb 20, 2023 8:27 am My Weathertech Frunk liner was installed at the same time as the OEM rear liner. The rear liner is badly warped around the entire periphery while the Weathertech one looks like the day I purchased it. The OEM vertical lips are thinner and flimsier than the one from Weathertech.
I'd like to know what you think about the Lloyd's when you get it. I'd also like to see how it looks in your car.
I'm wondering it the rear liners are as thin as they are due to the amount of flexing required to get them squished into place. The front Porsche frunk bins/liners are made from a far more sturdy material. The walls are tall and there is no thin material or flexing like the ones Porsche makes for the rear.
I think you’re correct. The rear liner almost has to be folded in half to fit in place
FLCAYMAN
Has thanked: 30 times
Been thanked: 35 times
As you can see, a warped mess. The frunk bucket is great. This, not so much. Glad I didn’t pay for it.
718-4Me
Has thanked: 23 times
Been thanked: 26 times
P_Coastal wrote: Thu Feb 16, 2023 9:36 pm Ordered one from Lloyd Mats Store, I hope all works out 8-)
I have Lloyd's floor mats and trunk pad, they're beautiful and match my black and red theme. I also ordered GT4RS meat trunk bar and rear trunk trim, these are black, looking forward to installing and will post pics when done!Image
718-4Me wrote: Wed Feb 22, 2023 1:46 pm
@718-4Me I just received and installed my Lloyd’s trunk pad. The fit isn’t perfect - there are a few gaps along the perimeter but far better than the OEM floor mat. Lloyd’s wouldn’t let me order it with the Porsche logo. Was that added later?
718-4Me
Larry C wrote: Wed Feb 22, 2023 2:24 pm
No that's the way it came, as I said i have their floor mats also and they also have the red Porsche logo. I must say the trunk mat from them fit very well.
#19
@718-4Me @P_Coastal Lloyd’s doesn’t allow any Porsche or Porsche related logos on their mats at this time. I couldn’t even select “GTS.” Also, from your rear mat photo, it looks like a perfect fit. My mat does have several areas where there are significant gaps (3/4 inch) between the mat’s border and the trunk wall.
