Not now
Install
Hide
How to do it?
Here is my version of the late 944 Windshield Wiper Nut Cap, which attempts to be as true to the original as possible.... The picture shows it printed in a high-resolution resin, but it does pretty well on a standard FDM printer in ABS.
Reminder, you need to be registered with at least 1 post to download the .stl file.
I made a small addition to the .stl file that you provided. I'm still pretty new at this but can you run a sanity check on whether there are major issues with the design I've produced? I added the embossing via Tinkercad and I don't have any idea if it's messing with the original file in a way that might break the print.
At any rate, if you can check it out, I'll give it a shot on my printer.
