This came up in another thread but I didn't want to bury this in a long thread about something mostly unrelated. I've mentioned this before, including to FTECH9 but never got to the bottom of it. As best I can tell, the "% Open" entry for the ISV data is illogical. It seems directionally backwards, it goes up when the ISV is closing more and vice versa. Not sure if it should be labeled % Closed or if there is some more complicated software thing going on -- or if maybe I'm missing something/confused? At any rate, maybe Joe @FTECH9 will see this and weigh in.
Focus 9 ISV Data Log
- Has thanked: 952 times
- Been thanked: 4078 times
Is it referring to electrically open or closed?
Supplying a charge to either side of the terminal made it move either direction restricting the opening but no charge opened the air passage. Edit: sorry I think I had it backwards
Voltage opened it
No voltage closed it
Been a while since I played with it when I resealed my ICV and posted my pics.
Not putting much thought into this at the moment as I am preparing for a big motorcycle trip
Voltage opened it
