IMS bearing question!
Posted: Fri Aug 19, 2022 5:12 am
Can I use my car's, 2005 Carrera S stick/coupe, VIN to determine if its IMS bearing has been repaired by the previous owner?
https://carpokes.com/
Welcome to Carpokes! I think you might be able to find proof that is WAS replaced, but if you find nothing I don't think you can draw a solid conclusion, since so many independent shops do this repair. A dealer might be able to tell you if it was repaired/replaced at a Porsche dealer, but lots have been replaced with non-Porsche solutions for which the Porsche dealer network may have no record. One of the most common solutions is LN Engineering and they actually try to maintain their own searchable database here:Gunship wrote: Fri Aug 19, 2022 5:12 am Can I use my car's, 2005 Carrera S stick/coupe, VIN to determine if its IMS bearing has been repaired by the previous owner?
