Everything you need to know including how to remove those pesky panels under the car with detailed diagrams and parts list. Be sure to check the description for more details.
The Ultimate 718 GT4/Spyder Oil Change Guide
- JetFuelOnly
- Has thanked: 44 times
- Been thanked: 125 times
edwordsigh
- Has thanked: 2 times
- Been thanked: 2 times
Danial — just finished watching this video. Super helpful. Thanks for the awesome content.
- Been thanked: 4085 times
Great video as usual from JFO! I'd be tempted to take a 4" hole saw to the pan below the drain plug, add a few Rivnuts, and make up an access panel, so you can use to drain the oil without taking all the other panels off.
- JetFuelOnly
That’s a good idea! Need more than a hole saw though because I’ll need access to the filter.
Hey that is an awesome video... thanks! But sheesh, now I'm tempted to pay someone to do this. Hahah.
FYI - I haven't done a change on the 718 but I've found that often times when you remove the oil filter more oil comes out... (whatever is in the lines to and from the filter housing). While it's a tiny amount, you may want to remove the oil filter with the drain plug out just to be sure.
- JetFuelOnly
Hadn’t noticed that! Thanks for the suggestion.
Moving this to the 718 board and bumping it for the benefit of all the new 718 people who have joined Carpokes since this video came out.
Great video! I think I need to pick up the license plate stand-offs! I just got a 2019 718 Cayman Base model for autocross. So far I've changed the plugs, air filter, cabin/hvac filters, brake flush, and inspected a few other items. Drive belt tensioner is failing (covered in oil/hydraulic fluid) and a transmission leak of some sort - or assumed to be a transmission leak. Still have the factory warranty on it so I'll be taking it in for those two items. Oil change is next on my agenda.
2019 718 Cayman Base Model (2.0L), PDK, PASM, Sports Chrono, Torque Vectoring, HRE wheels with Bridgestone RE-71r tires. SCCA SOLO Autocross in A Street.
