Hello I went to fix my non functioning sunroof, and realized someone had attempted to fix and removed two parts I need to try and finish troubleshooting. Both on the motor track in the boot. The first is the lid(62) that hold the cable in at the motor , it’s just a rectangular cover with three small screw holes and a bevel inside to hold the cable;
and the second is the driver, or follower(63) which mounts at the end of the cable and rides along the track, with in my case was held in by a crimp(64), a later version had a screw which threaded into the cable end.
Trying to buy these online seems impossible! Is there a way I can o-en without these parts? Manually?
Hopefully someone has damaged them and recreated with a 3d printer! In which case I’d love the file or purchase the parts from you!
Part for the sunroof is
Lid 944 564 527 00 (#62), and
Driver (follower) 944 564 425 01 (or 02) - proceeding number. (#63)
See photos
Early 944 sunroof parts
1984 Porsche 944
"Wicke" aka sweatpea
Alpine white, black interior, white Fusch 15’s
- one family owner,
mostly all original
- one family owner,
mostly all original
- Has thanked: 961 times
- Been thanked: 4160 times
If you wanted to take the broken ones off and send them to me, I could try to model them for you... That looks like nylon, so probably needs to be printed in something strong... They also look like pieced you might be able to machine pretty easily?
