The odometer gear on my bench-test cluster broke, so I bought a gear for $25. When I got it, I could help but wonder if my Formlabs printer could print the tiny detail and make a functional replica. After a short odyssey learning about gear modulus, pressure angles, and a bunch of other esoteric gear lingo, I was able to model a replica of the gear I bought, and printed it. Pretty excited that it seems to work like a charm! I have it running on the bench cluster now, and it's up to 50+ miles. This gear is printed in a general purpose resin, but I have a super hard resin for the 'production' versions. Assuming all goes as planned, we can say goodbye to the days of $25 odometer gears!
Grey one is mine; white one is from eBay....
Odometer Gear Nirvana
- Has thanked: 935 times
- Been thanked: 4006 times
- painenneck
- Has thanked: 2 times
- Been thanked: 4 times
They are available on Etsy for $15 and change. Just bought one; works well.
With all these parts you're making you'll have to start hiring employees and offering medical, dental and 401K!
Yeah, I did see after-the-fact that there were some cheaper ones out there. Was the Etsy one 3D printed?painenneck wrote: Mon Jul 25, 2022 7:31 am They are available on Etsy for $15 and change. Just bought one; works well.
As for employees, it's not entirely out of the question if i could find someone good at HTML/PHP, 3D-printing, SEO optimization, graphic design, advertising, hardcore Porsche mechanics, bookkeeping, shipping and receiving, and public relations.
- painenneck
I don't know if it was.
- Larry C
- Has thanked: 592 times
- Been thanked: 667 times
Buy a clone machine and you may have one applicant.Tom wrote: Mon Jul 25, 2022 7:44 amYeah, I did see after-the-fact that there were some cheaper ones out there. Was the Etsy one 3D printed?painenneck wrote: Mon Jul 25, 2022 7:31 am They are available on Etsy for $15 and change. Just bought one; works well.
As for employees, it's not entirely out of the question if i could find someone good at HTML/PHP, 3D-printing, SEO optimization, graphic design, advertising, hardcore Porsche mechanics, bookkeeping, shipping and receiving, and public relations.![]()
You're hired! They now make resin printers capable of extremely high resolution prints (under 50 microns) for less than 3 tanks of gas. My Form 3 is part of the Formlabs eco-system, which caters to dentists, jewelry makers, etc. so is just a foolproof workhorse for the most part, but at less than 1/10th the cost, some of these new printers claim to print faster with higher resolutions, etc. so are mighty tempting. Can't really say whether they are as reliable and hassle free, but for the price, seems hard to go too wrong. For example:Larry C wrote: Mon Jul 25, 2022 9:23 amBuy a clone machine and you may have one applicant.Tom wrote: Mon Jul 25, 2022 7:44 amYeah, I did see after-the-fact that there were some cheaper ones out there. Was the Etsy one 3D printed?painenneck wrote: Mon Jul 25, 2022 7:31 am They are available on Etsy for $15 and change. Just bought one; works well.
https://www.amazon.com/dp/B09QGW5J8T/re ... g_ana_1-20
In the meantime, I let my speedometer run all night at 60mph, and the gear is going strong for over 900 miles now.... I just cranked it up to 120 to see how that does for a while. If this more general purpose resin lasts thousands of miles, the high-strength resin I got for this should last a very long time.
Zirconocene
- Has thanked: 78 times
- Been thanked: 48 times
You are on fire lately with the cool printed parts. If these work out how you think I'd be in for a couple, for the 944 and 968. Both of those cars are going to eventually get the gauge cluster sanded and resprayed; that stippling has started. I figure I can do a proactive gear change with everything off and out.
Awesome stuff, thanks for sharing!
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
Yes, sitting at my desk designing parts and hitting 'print' is just soooo much easier than actually working on the car.Zirconocene wrote: Mon Jul 25, 2022 3:34 pm You are on fire lately with the cool printed parts. If these work out how you think I'd be in for a couple, for the 944 and 968. Both of those cars are going to eventually get the gauge cluster sanded and resprayed; that stippling has started. I figure I can do a proactive gear change with everything off and out.
Here's the gear after 1200+ 'miles' on the cluster -- no visible wear at all...
- painenneck
Has anybody heard of the reasoning behind Porsche using a different plastic for this one gear in the cluster? I mean, seriously?
Yeah, not sure, but that one gear turns on a perpendicular worm gear, so the gear teeth essentially slide against each other to make a 90 degree angle. If I had to guess, the clever engineers at VDO wanted to use a material that was self-lubricating, so that the gear teeth wouldn't wear down. So instead of using a gear that would wear out in 100k miles, they used one that would turn into crusty pine resin after a decade or two.painenneck wrote: Tue Jul 26, 2022 6:34 am Has anybody heard of the reasoning behind Porsche using a different plastic for this one gear in the cluster? I mean, seriously?
