FOR SALE - Spec Boxster Race Car
1999 Porsche 986
Post things for sale here!
Kelly
Has thanked: 17 times
Been thanked: 6 times
1999 Porsche 986 - SPB #65
This car is a low mileage (<86K) Spec Boxster with a fun history. It went originally from a daily driver in 2016 to the 2017 PCA Zone 7 showroom stock autocross champion. Then in 2018, it went through a transformation into the racecar you see today.
#65 was largely built at BRRacing in Los Gatos. A Lifeline three nozel fire supression system and safety cut offs with rapid disconnects and all the needed and required nets and safety gear are installed. Its suspension was built new to spec at BRR.
It has a complete modern cage for maximum safety professionally installed by TC Design in Campbell.
This car has a current up to date PCA log book in good standing and was successfull right out of the pits with a first place finish in the 2018 summer POC time trials at Laguna Seca immediately after completion - and then a podium finish in its first enduro at Buttonwillow at the end of 2018.
#65 was raced successfully in 2019 & 2020 finishing fouth over all in the PCA West Coast Series.
In ’21 it was out four times successfully competing and completing every race entered with new personal records set at Sonoma and Buttonwillow and two podium races at Fontana to finish the 2021 season.
In 2022 it’s raced only one weekend at Laguna Seca. Completing a very competitive and successful weekend of racing without incident or problem in fast company!
#65 was completed in 2018 with the following components & upgrades -
Bilstein PSS9 Spec Boxster suspension
Swift Spec Boxster springs
GT3 front swaybar
GT3 front control arms
Tarett Engineering front and rear adjustable drop links
Tarett Engineering rear toe control arms
Tarett under-drive pully
Wevo semi-solid engine and transmission mounts
Slotted brake rotors
Stainless steel brake lines and GT brake ducts
Pagid brake pads -(yellow in front / black in back
Odyssey 925 lightweight battery w/ trickle smart charger connect
Quick battery disconnect inside and out
Tarett Precision transmission link
Rennline shift tower riser
Porsche Boxster S center radiator
LN engineering Deep sump upgrade and oil starvation pickup
Spec Boxster race exhaust system
TC Design roll cage - to current PCA SPB spec w/ compliant padding
Ultra light Sheridan fiberglass hard top w/ Lexan rear window
OMP Super Quadro steering wheel
Rennline steering wheel quick disconnect
Racetech 4009HR seat on sliding base
RaceTech seat belts
Lifeline 3 nozzle fire supression system
Side window / roof / center safety nets
Wire mesh front and side intake insert sets
Wheel bolt studs
Motorola radio with press to talk on wheel
Cool Shirt with variable switch on dash
This car is race ready. The factory original arctic silver paint and body look good with only a couple minor signs of any previous nudges. It has a clean car fax and non-opd clean California title in hand.
This is a competitive car - a very strong running Spec Boxster (Dyno’d at 204 at the end of 2020)
Meticulously maintained - Fresh Mobil 1 full synthetic oil and Motul 660 brake fluid - ready to race today
Please visit http://LeterBuckRacing.com to see more video and many photos of the car and our adventure.
Asking $35,000 obo
PCA logbook and Porsche Certificate of Authenticity included.
Kelly @LeterBuckRacing
Boxster 986.1 / 996.1
Porscheanimist
