I had a set of new Apex wheels and Falken RT660 tires in my garage for a long time before I could use them because they didn't fit as expected! I finally got around to adding Tarett Engineering camber plates and adjustable toe links. If you intend to do any of these things you should watch this!
Apex Wheels with Tarett Camber Plates and Toe Linkx
- JetFuelOnly
- Has thanked: 44 times
- Been thanked: 125 times
- Throttlesteer
- Has thanked: 15 times
- Been thanked: 39 times
How much camber were you able to get? What are your thoughts on camber plates vs. GT3 LCAs?
- JetFuelOnly
3.0 front and 2.4 rear. I had shims before for 2.5 degrees but they were contributing to the 265 tires not fitting up front.
I think 3.5 is also possible with these plates.
