Here is a quick video of an easy off the shelf intercooler sprayer using a $12 washer pump and some fogger nozzles… I’ll add pictures and a second video of V2 fogger
Cheap DIY intercooler sprayer!!!
- Has thanked: 943 times
- Been thanked: 4028 times
Is there an earlier video showing where to get the plumbing parts and pump? I have a custom duct (same i/c) but could still make this work. Did you just wire in a push button to the cabin to activate it?
Parts are listed in the first video just opened the videos description tab, it’s all amazon sourced, I was going to wire it up to the washer plug….. but then thought it would be a great Arduino project , could program it to spray whenever surface temps reached whatever SettingTom wrote: Mon Jul 11, 2022 6:41 pm Is there an earlier video showing where to get the plumbing parts and pump? I have a custom duct (same i/c) but could still make this work. Did you just wire in a push button to the cabin to activate it?
Here’s the list for easy access
Mister jets
Aimego Outdoor Misting Cooling... https://www.amazon.com/dp/B08V972ZXT?re ... b_ap_share
Pump…. This one’s cheap but works, it’s a bit on the loud side, I’m sure a better pump could be sourced
Windshield Washer Motor Pump, Keenso SIA0050 12V Universal Windshield Washer Pump for Car Van Bus Truck https://a.co/d/7X8KCbn
Mister jets
I like this idea more, you use your windshield washer stalk to trigger the sprayer lolDGUN951 wrote: Mon Jul 11, 2022 7:01 pmParts are listed in the first video just opened the videos description tab, it’s all amazon sourced, I was going to wire it up to the washer plug….. but then thought it would be a great Arduino project , could program it to spray whenever surface temps reached whatever SettingTom wrote: Mon Jul 11, 2022 6:41 pm Is there an earlier video showing where to get the plumbing parts and pump? I have a custom duct (same i/c) but could still make this work. Did you just wire in a push button to the cabin to activate it?
Porsche 944S2 5MT '91
BMW E39 540iT 6MT '00
IG: @stitch2k1
IG: @stitch2k1
naesjr wrote: Tue Jul 12, 2022 9:37 amI like this idea more, you use your windshield washer stalk to trigger the sprayer lolDGUN951 wrote: Mon Jul 11, 2022 7:01 pmParts are listed in the first video just opened the videos description tab, it’s all amazon sourced, I was going to wire it up to the washer plug….. but then thought it would be a great Arduino project , could program it to spray whenever surface temps reached whatever SettingTom wrote: Mon Jul 11, 2022 6:41 pm Is there an earlier video showing where to get the plumbing parts and pump? I have a custom duct (same i/c) but could still make this work. Did you just wire in a push button to the cabin to activate it?
100% could for easy install
If you have the headlight washers, you could tap into that circuit on the stalk, to preserve the windshield washer function... Can't imagine there are many people who really use/need headlight washers on these car, but windshield washers do come in handy.
