Air Conditioning Strange Behavior
Leader
Has thanked: 62 times
Been thanked: 183 times
My new 2022 CGTS has a strange anomaly with its air conditioning. Sometimes on first start-up, the AC compressor does NOT come on and the Auto Air blows warm.
Stopping, shutting the car off, then restarting resolves the glitch and all is back to normal.
Also, I have experienced the AC compressor turning itself back ON after a few minutes of driving, no car restart needed.
Anyone else experiencing this strange AC misbehavior?
I suspect the AC compressor activation is getting skipped in the start-up sequence on occasion. Software problem?
2025 Macan GTS
2023 VW Golf R 20AE
2022 718 Cayman GTS 4.0
FLCAYMAN
Has thanked: 30 times
Been thanked: 35 times
That’s not something I’ve experienced over 11 months with my CGTS. Sorry I don’t have better advice other than to check with your service manager.
Southbama
Has thanked: 61 times
Been thanked: 31 times
I have experienced this once in my '22 GTS 4.0, thought it to be bizarre. Due for 10,000 mile service in a couple of months and it will be mentioned to the SA. I suspect a software issue.
Been thanked: 4080 times
Southbama wrote: Tue Jun 21, 2022 12:12 pm I have experienced this once in my '22 GTS 4.0, thought it to be bizarre. Due for 10,000 mile service in a couple of months and it will be mentioned to the SA. I suspect a software issue.
My car did that one time. On my car, the climate control is operated through the PCM screen. Not sure if that's true on the 718? At any rate, when it happened, I went to the climate control screen and the buttons that normally let me turn on or off the a/c simply weren't there. Subsequently, my PCM screen started malfuntioning and would go monochrome from time to time. The dealer replaced my PCM screen and the neither the screen or the a/c has had any issues since.
Southbama
Not switched on/off thru PCM. If it is, I am not aware of that.
OttawaSteve
Has thanked: 5 times
Been thanked: 15 times
Not sure about AC, but glitches with various systems, mostly software related, have been fairly common on both my 981 and my 718. After several months of perfect operation, the bluetooth connection to my phone and to my CarPlay adapter is acting strangely. As some of these issues seem to magically resolve themselves, I am waiting hopefully.
2021 718 CGTS 4.0
981 CS (gone)
Turbos7903
Yes. Had that issue with my 2022 GTS4.0after maybe 15 mins of driving it resolved . Not many drives since then but ever since the air is cold
Nearly immediately
Has thanked: 594 times
Been thanked: 668 times
I have a 2022 CGTS 4.0. Twice, when starting the car with the AC button on, the air compressor didn’t turn on even though the AC light was on. Both times, I turned off the ignition and restarted and the problem was corrected - I’ll mention it at my oil service in two months.
chester
Has thanked: 35 times
Been thanked: 14 times
Software glitches. Does not bode well for Porsche EV future where software, not mechanical, is king.
I really detest my 718 climate controls and operation, including the incessant loud fan speed.
Mid-engine aficionado from Austin, Texas
Has thanked: 1059 times
Been thanked: 623 times
Known Issue, fix recently released, see here:
https://www.718forum.com/threads/a-c-ma ... ost-300771
