You would think keeping the D side door shut would be easy even without the door handle. Not so. At Sunday;s C&C someone suggested coat hanger. Sure but the window will not go down. Bungey cord stretches too much.
Easiest thing is probably replace the door with handle that works, window motor that works etc Does a 944 door fit a 968?
door flies open/// 944 968 same door?
07turbeaux
- Has thanked: 14 times
- Been thanked: 8 times
