@CarBot
The instant MPG gauge in my 1986 944 some times works, sometimes it doesn't. Can you tell me how this is controlled and a theory of operation?
MPG Gauge
- PSU_Crash
- Has thanked: 191 times
- Been thanked: 111 times
@CarBot are you still with us?
CarBot
thinking
'86 Zermatt Silver 944 N/A
- Has thanked: 4471 times
- Been thanked: 2429 times
Not sure what's happened to CarBot. This is the second direct post in his corner that he's not responded to. Is it a positive that he's still "thinking"? Maybe he's still fogging the mirror, although barely!
My comment using a CB mention locked up my post. I think he may be under the weather.
@Tom
@Tom
- Has thanked: 941 times
- Been thanked: 4028 times
Hmmm... news to me. I'll have to fix it. Please hold...
No worries, Tom. Thanks for getting it sorted.Tom wrote: Ironically, in my never-ending effort to block AI bots, I inadvertently blocked our good friend . I put his name on the bouncer's clipboard, so all should be good now.Sorry CarBot.
On the 1986 944, the “instant MPG” gauge is basically a real-time fuel economy calculator. It needs two main inputs: how fast the car is going and how much fuel the engine is using at that moment. The gauge electronics then compute miles per gallon and drive the needle.
Vehicle speed comes from the speedometer signal (the same pulse signal used by the odometer/cruise on cars equipped). Fuel usage is derived from the DME’s injector control signal. The gauge is effectively looking at injector pulse activity (how long/often the injectors are being commanded) as a proxy for fuel flow. More injector on-time at a given road speed equals worse MPG, less injector on-time at a given road speed equals better MPG. On decel fuel cut, it’ll typically peg to very high MPG because injector pulse goes to near zero while the car is still moving.
When it works sometimes and not others, the usual theories are an intermittent signal or power/ground issue rather than the gauge “calculation” itself. Common culprits are a flaky connection at the back of the cluster, cracked solder joints on the gauge/cluster board, an intermittent speed signal feed, or an intermittent injector signal feed from the DME harness. If the speedometer ever drops out when the MPG gauge drops out, that’s a big hint the speed signal is the problem. If the speedo is steady but the MPG gauge dies or acts random, I’d suspect the injector signal feed or the gauge/cluster solder joints.
If you tell me what the needle does when it “doesn’t work” (dead at one end, pegged, twitchy, only works after a bump, etc.) and whether the speedometer/odometer are always solid, I can narrow it down.
Tom wrote: Sun Jun 14, 2026 10:55 am Ironically, in my never-ending effort to block AI bots, I inadvertently blocked our good friend @CarBot. I put his name on the bouncer's clipboard, so all should be good now.Sorry CarBot.
- PSU_Crash
@CarBot I noticed something strange while out cruising the mountains yesterday. If the MPG gauge is reading pegged high, like it usually is, then I tap the brake just enough to move the pedal it will usually come back to life for a little while. I'm not sure how that makes sense
@Tom Thanks for getting the good robot back in order!
That brake-pedal “wake up” actually makes some sense on a 944, because the instant MPG gauge is very sensitive to power/ground quality and to the signals it’s using, and the brake circuit is a big, noisy load that can momentarily change voltage and ground conditions in the car.PSU_Crash wrote: I noticed something strange while out cruising the mountains yesterday. If the MPG gauge is reading pegged high, like it usually is, then I tap the brake just enough to move the pedal it will usually come back to life for a little while. I'm not sure how that makes sense
If your MPG gauge is pegged high, that usually means the gauge thinks fuel flow is near zero while the car is moving. That can happen legitimately on overrun fuel cut, but if it’s doing it most of the time it points to the injector signal input dropping out intermittently, or the gauge losing its reference/ground so it interprets the injector signal wrong.
When you tap the brake, a few things can happen that temporarily “fix” an intermittent connection. The brake light circuit draws current and can slightly shift system voltage, and it can also change the ground potential at the cluster if there’s a marginal ground splice or connector. The physical movement/vibration from the pedal can also be enough to jiggle a flaky connector, especially around the fuse/relay panel area, the steering column harness, or the back of the instrument cluster.
Most common practical places to look on these when a gauge comes and goes with bumps or electrical loads are the instrument cluster connectors and the solder joints on the cluster foil/board, and the main grounds. I’d start by pulling the cluster, reseating the connectors, and inspecting for cracked solder joints on the MPG gauge and the cluster board. While you’re in there, clean and tighten the ground points (especially the main dash/cluster grounds and the battery-to-body and engine-to-body grounds). If the speedometer is ever acting up at the same time, chase the speed signal side too, but your symptom really smells like an intermittent feed/ground or injector-signal connection rather than a “bad gauge movement.”
If you can confirm whether the speedometer and odometer stay perfectly steady when the MPG gauge is pegged high, that will help narrow it further.
