Bad water pump? Troubleshoot/diagnosis help
Posted: Mon Jun 01, 2026 2:09 pm
Thanks to playing with a standalone ECU, I've been able to read the DME temp sensor directly and learned my car has been operating at well over 110C, typically as high as 120C. The gauge sensor reads low, so I never knew, but it explains why I was often getting coolant steam despite confirmed multiple times I had no leaks. At first I thought the ECU was programmed wrong, but confirmed the right pull-up resistor and sensor settings, and verified the coolant temp with a infrared thermometer aimed at the coolant crossover pipe.
My first thought was thermostat, so I went through that (painful) replacement, and replaced the aux turbo thermostat, and DME temp sensor while I was at it, as well as a fresh rad-to-pump hose. I meant to replace the gauge temp sensor as well, but somehow ordered a two prong sensor. I got the same behavior afterwords, so asked Gemini for troubleshooting help and it suggested the water pump, as indicated by feeling pressure surge in the radiator hose under revving, or seeing flow into the reservoir. I can't figure out how to reach the hose while revving, so just viewed the reservoir with the cap off - I seem to get intermittent flow, and not a whole lot.
I'm guessing that means the internal pump impeller is slipping on the shaft? But it's a big expensive job to replace, so wanted to double check any other culprits while I'm at it. Is there anything else it can be? Are there other steps I can do to verify a faulty pump? Not getting any bad sounds or leaks from the pump, although I did notice a very loose fit for the internal thermostat seal that is supposedly hard to remove. Mine literally fell out with the thermstat removed.
Side question - is it possible to get very different temp readings at the DME vs gauge temp sensors? Just wondering if the gauge sensor is actually somehow outside the failed pump circuit so not getting hot coolant.
