Air Box broken tabs fixes, anyone?
Posted: Wed May 27, 2026 8:37 am
by Spencan
My rear tab on my factory airbox, below the charge hose strap, is gone on the bottom of the air box. I have been scouring the internet for possible solutions since I noticed that the 3 remaining screw attachments are not doing enough to keep debris and hot air from entering that corner; I can see the pattern of dirt on my K&N filter.
What have any of you done to fix or create a tighter seal for those missing tabs?
Re: Air Box broken tabs fixes, anyone?
Posted: Wed May 27, 2026 1:54 pm
by gb951
Posted: Wed May 27, 2026 2:00 pm
by pizatski
I had the same problem, both the tab on the upper cover and the part the screw threaded into were smoked.
I tape formed and jb welded the tab at the top and drilled a hole.
For the bottom part, I printed this in ABS:
https://www.thingiverse.com/thing:47981 ... e_vignette
and glued/plastic welded it in place.
Posted: Wed May 27, 2026 2:44 pm
by Spencan
pizatski- Thanks! That's is exactly what I was hoping for! I was looking for some kind of mini clamp or super clamp, etc. but not even considering 3D printing and plasti-welding/gluing the missing tab,
Posted: Wed May 27, 2026 9:45 pm
by fasterfaster
Same, I initially just plastic welded them, but it didn't hold. Ended up switching to epoxy to get good adhesion all the way through and be able to build it up and reinforce them. Not the prettiest, but the best solution short of a new $500 airbox.
Posted: Sat Jun 06, 2026 11:21 am
by Spencan
Posted: Sat Jun 06, 2026 1:28 pm
by pizatski
Spencan wrote: Sat Jun 06, 2026 11:21 am
I couldn’t print the file on my FlashForge ADM5 so used some ABS scraps from a previous project, a dremel, sand paper, brass inserts and ABS cement. image.jpgimage.jpgimage.jpg
Looks good and like it'll hold up just fine. Nice job!
