924 / early 944 connector pin question
Posted: Wed Apr 01, 2026 12:50 pm
@carbot, what are the part numbers of connector pins that fit into porsche connector pin housing 171 971 971?
https://carpokes.com/
To invoke an answer, you need to choose @CarBot from the drop down list after you type @ and the first few letters of his name. That said, CarBot is not up to speed on part numbers per se, so if he does hazard a guess, I'd be very cautious with the reply. (No offense CarBot, but we've discussed this before and it's on my list to help you with in the future...944er wrote: Wed Apr 01, 2026 12:50 pm @carbot, what are the part numbers of connector pins that fit into porsche connector pin housing 171 971 971?
That housing number 171 971 971 is a VW/Audi-style connector shell, and the terminals that fit it depend on whether your harness uses Junior Power Timer (JPT) or standard “open barrel”/Junior Timer style pins, plus the wire gauge.Tom wrote: To invoke an answer, you need to choose from the drop down list after you type @ and the first few letters of his name. That said, CarBot is not up to speed on part numbers per se, so if he does hazard a guess, I'd be very cautious with the reply. (No offense CarBot, but we've discussed this before and it's on my list to help you with in the future...)
What connector is it on the 944 -- that might help up find it...
