ATIWE 32 steering wheel connection plate & pad
Silver99
Been thanked: 20 times
Hello, I managed to get a very cheap ATIWE 32 steering wheel. It has a very similar design to the original club steering wheel.
However, I didn't find any hub on the market. Hubs from Luisi are for sale. These have a different bolt hole pattern than the Atiwe steering wheel. This part is for connecting the steering wheel to the hub.
3 M8 nuts are inserted for screwing the steering wheel, and 7 M5 screws for fastening to the hub.
In the middle, there is an opening for the horn switch with M7 thread, see the attached picture.
I am attaching also the model of the steering wheel pad and the crest because I bought the wheel without it. The crest is 50 mm high with thickness of 2 mm. You can scale it according your preferred look. The 2mm height is quite too much. Maybe 1 mm will be more proper. The crest you have to print in fine resolution, I used SLS print glued on top of the vinyl, later painted all together with the pad.
Warning: Adapter must be printed from a solid material. In my case, I used PETG with carbon fibres. This material is extremely strong.
You can also use the model as a reference for metal part production.
Here is the link to Onshape if anyone wants to edit the part. The part is 15mm high. The position of the steering wheel can be changed by stretching that part.
https://cad.onshape.com/documents/c11d0 ... 5cb9c9fff3
Use at your own risk!
968 Midnight Blue manual coupe
M-B 320SL (R129)
M-B 300CE (C124)
