simple 944/968 phone holder
Silver99
Been thanked: 18 times
Hello, I made a phone holder that attaches to the central vent. It is two parts that are glued together. I printed from ABS and glued with acetone. For the size of your phone, the part into which the phone is inserted must be dimensionally adjusted. The internal dimensions are 74mm wide and 10mm thick.
Note the position of the clip is not in the centre but has been moved to the left to avoid conflict with dashboard. For RHD cars you need to glue it opposite.
968 Midnight Blue manual coupe
M-B 320SL (R129)
M-B 300CE (C124)
