Is there an alternative to soap for suspension bushing installation?
The essential question is how the bushings function. Do they regulate suspension movement in shear or are they solely serving a cushioning function? If it is the latter, a high quality non-petroleum based grease should function well while also serving a corrosion resistant role as well. Thoughts?
spacecad3t
- Has thanked: 92 times
- Been thanked: 75 times
I use WD40 dry silicone spray, during install and every fall before winter.
