Timing Belt Spring Tentioner Variations
Posted: Mon Dec 22, 2025 12:10 pm
by libarra82
Hi all,
Did the spring tensioner have multiple variations? The one I have doesn't have the holes for the spanner tool. It's not easy getting good leverage with the spanner tool in the slots it does have, I ended up breaking a pin off the tool trying.
I was able to adjust by pressing counter clockwise on the roller bolt using a socket and wrench, is this ok? Could it potentially loosen the bolt by doing so.
Thanks
Re: Timing Belt Spring Tentioner Variations
Posted: Fri Dec 26, 2025 5:57 pm
by michaelmount123
i've always used the nut on the roller to back the tension off during assembly/disassembly. Yes, use a little care to avoid loosening the bolt, or at least make sure it's gutentite before the tensioner is installed. No special tools required.
MM
Posted: Sat Dec 27, 2025 4:41 pm
by libarra82
Great! Thank you for confirming.
