LWBS Removal
aarosmith
Has anyone removed a LWBS in a 718? Thinking about removing the passenger LWBS to give my dog some room to lay down :D
Do I have to disconnect the battery for the airbag sensor? I see there are 4 bolts, not sure if there is anything else I'm missing.
Thanks!
Crazy Eddie
Has thanked: 212 times
Been thanked: 78 times
aarosmith wrote: Tue Mar 08, 2022 6:25 am Has anyone removed a LWBS in a 718? Thinking about removing the passenger LWBS to give my dog some room to lay down :D
Thanks!
I have only done this in the 981 GT4 Don’t know if the 718 is different it was simple just a harness snap out with a zip tie to cut, and the 4 bolts and your done but!! Big but … If you remove the seat and drive the car or turn the key you’re going to get a warning airbag sensor light coming on and it won’t go off until it’s cleared.
Best
Ed
