944 Tachometer Test and Calibration
Been thanked: 4018 times
I had an offline question the other day about whether the 944 tachometer can be calibrated. The short answer is yes! There are two pots on the side of the tach and the upper one allows you to adjust the reading. I discovered in the process that my spare tachometer wasn't working, so also came up with a super simple way to tell if the tachometer is dead or alive, using just a 9v battery and a small screwdriver (or paperclip or whatever) -- as shown in the first part of this video. For anyone who wants to calibrate their tach on the bench using my set-up, I'll also post the code for the Arduino in the download section below. Happy to answer any questions. Hope this helps!
spacecad3t
Has thanked: 86 times
Been thanked: 70 times
Thanks Tom! Never mind, my audio was muted, you explain it...
PSU_Crash
Has thanked: 190 times
Been thanked: 111 times
Hopefully my cluster is back in for a while, but I'll definitely do this the next time it's out!
What's the relation between Hz and RPM?
Thanks for the how to
Edit: Nevermind, I read the code. Another reason to pick up another Arduino
PSU_Crash wrote: Thu Oct 23, 2025 6:10 pm Hopefully my cluster is back in for a while, but I'll definitely do this the next time it's out!
Fun fact: I've done quite a bit of Arduino coding for various projects. I started doing a program to step through the rpms and was finding it tedious -- so I went to ChatGPT and asked it to write the sketch and... it got it perfect on the first try. It had programming techniques I'd never seen, so I asked it to dumb it down so that humans could understand it, and it did that too. All I did was edit the comments a bit -- didn't touch the actual code at all. It's a brave new world!
If you are picking up a new Arduino to do this, consider the Mega2560 over the Uno. The Mega2560 has a crystal oscillator that creates a reasonably accurate clock. (And, the pulse timing relies on the clock obviously.) The Uno has a ceramic resonator, which is significantly less accurate. The scope says the Mega2560 generated a pulse that was about 5998 rpm, when programmed for 6k, so plenty accurate for this purpose. An Uno might not be as close.
spacecad3t
Tom wrote: Thu Oct 23, 2025 8:18 pm
I have also used ChatGPT to write or improve Arduino sketches, its works VERY well.
Evan
Has thanked: 10 times
Been thanked: 20 times
Tom wrote: Tue Oct 21, 2025 3:29 pm I had an offline question the other day about whether the 944 tachometer can be calibrated. The short answer is yes! There are two pots on the side of the tach and the upper one allows you to adjust the reading. I discovered in the process that my spare tachometer wasn't working, so also came up with a super simple way to tell if the tachometer is dead or alive, using just a 9v battery and a small screwdriver (or paperclip or whatever) -- as shown in the first part of this video. For anyone who wants to calibrate their tach on the bench using my set-up, I'll also post the code for the Arduino in the download section below. Happy to answer any questions. Hope this helps!
That's a great find. The 9v battery trick is a really clever way to test it. Thanks for sharing the info on the calibration pot and the Arduino code.
spacecad3t
Tom, my Arduino is in use and Im curios if you had a sense of how much of an adjustment made 100rpm difference. I don't need mine to be dead on, just looking to get closer while Im in there installing your lovely gauge clusters :)
spacecad3t wrote: Sun Nov 02, 2025 6:14 am Tom, my Arduino is in use and Im curios if you had a sense of how much of an adjustment made 100rpm difference. I don't need mine to be dead on, just looking to get closer while Im in there installing your lovely gauge clusters :)
Very little! I'd guess like the width of the screwdriver slot. Although... you can get an Arduino these days for less than a can of Coke...
Image 11-2-25 at 7.54 PM.jpeg (572.61 KiB) Viewed 1098 times
spacecad3t
Tom wrote: Sun Nov 02, 2025 8:01 pm
Oh holy cow... havent looked in a few years.
Carmagic
Has thanked: 33 times
Been thanked: 266 times
Is that 9v battery trick only applicable for the 944 tach, or can that also be used for any other tach ? I have a few tach sitting around and would be good to know if these are still OK.
Thanks for posting this
Engelbert
