944 Cigarette Lighter Bulb Holder
Been thanked: 4017 times
On the oval-dash 944, Porsche changed the way they mount the light bulb for the cigarette lighter somewhere along the way. They originally included a bulb holder on the back of the plastic trim piece that the lighter sits in, but later eliminated that holder in favor of a holder that's integrated into the lighter's connector. As a result, if you buy a new piece of dash trim, it does not come with any way to mount the bulb (unless you also change the connector for the lighter). :roll: This little bulb holder is designed to stick to the side of the clock with a small piece of VHB two-side tape, closely approximating the location of the original holder. Works like a charm and very easy/quick to print, just be sure to use ABS or other temp-resistant plastic. :)
944 Cigarette Lighter Bulb Holder.stl
choochbamboozle
Has thanked: 16 times
That design is brilliant. I have the very same issue.
choochbamboozle wrote: Fri Sep 23, 2022 7:58 pm That design is brilliant. I have the very same issue.
Thanks. Curious how you found this? I made it and even I had forgotten about it. :lol:
Half Sack
Been thanked: 10 times
Thank you!
