I'm cleaning up my shed and I have a bunch of parts to get rid off. Here's the list, everything for $750. Or make an offer. I do not want to take the time to ship but I can drive to meet you halfway, for example. I'm at 02891.
944 341 103 05 - Cross member with engine mounts (not sure if they are good)
951 110 137 03 - Intercooler
951 110 310 03 - Pipe with couplers
951 110 311 04 - Pipe with couplers
944 106 143 02 - Fan shroud
951 575 131 00 - Intercooler duct
951 110 152 3R - Intake manifold with throttle body
951 606 121 01 - Throttle body
944 101 143 3R - Balance shaft carrier end cap
951 104 315 0R - Coolant neck
944 375 124 02 - Engine carrier mount
944 101 142 4R - Balance shaft bearing housing
944 101 147 01 - Power steering /balance shaft bracket
944 102 209 05 - Crank balancer
944 102 214 03 - Power steering pulley on crank
951 116 401 1R - Bell housing
951 111 199 4R - Downpipe
951 101 123 1R - Engine carrier mount
951 107 108 00 - Turbo oil drain pipe
951 107 317 05 - Turbo oil feed pipe
944 101 132 07 - Speed and reference sensor bracket, with sensors
07 04 16 00 - Blowoff valve
944 102 205 04 - 2 balance shaft pulley
944 105 125 02 - Crankshaft lower timing belt gear
CRP-25-568 - Lindsey billet oil filter
928 351 043 60 - Turbo S left front rotor
928 351 044 60 - Turbo S right front rotor
951 352 041 02 - 4 rear rotors
944 201 509 - Crankshaft
71 26182 10 - 4 exhaust pipe flange gasket - new in bag
71 25182 10 - 4 intake manifold gasket set - new in bag
71 23972 20 - 3 exhaust seal ring porsche - new in bag
71 24953 30 - Exhaust seal ring - new in bag
928 Motorsports Steel Heater Control Valve
