968 RMS tool
Silver99
Been thanked: 18 times
The Porsche 968 has an installation opening for clutch replacement. This makes it possible to replace not only the clutch or flywheel, but also the rear crankshaft seal. Due to limited space, seal installation is complicated. This tool ensures that the seal is pressed in using flywheel bolts tightened in a circular pattern.
I used other models found on the web to determine the bolt circle diameter. I printed the part from PETG material filled with carbon fibers and used large washers under the bolts.
968 Midnight Blue manual coupe
M-B 320SL (R129)
M-B 300CE (C124)
