Stripped Aluminum Shift Shaft and Wooden Knob — Looking for Fix Ideas (Not Manufacturer-Related)
Posted: Sun Jun 15, 2025 3:59 am
Hey folks,
I recently purchased a wooden shift knob along with its matching aluminum shaft adapter. The design is pretty straightforward: the knob threads onto the shaft, which in turn slides over a 3D-printed insert that fits onto the factory shift stem.
The parts arrived in good shape, pre-threaded, and everything looked promising. But during installation, things went sideways — the knob and shaft started to cross-thread, and once it started stripping, it just tore through the first few threads on both. At this point, the threads on both the aluminum shaft and the knob are toast. I managed to get the knob seated on the shaft, but with the threads chewed up, it won’t stay fixed.
A few important details:
• I need to be able to remove the shift knob from the shaft, because access to the set screws that fix the whole assembly to the factory stem is located underneath the knob.
• The 3D-printed insert isn’t super snug, so there’s a bit of play where the shaft meets the stem, which adds to the sloppiness.
• I’m not looking to go back to the manufacturer — this one’s on me. A little more support from them would’ve been appreciated, but I own the mistake.
What I am looking for is any advice from people here who might’ve faced similar issues. Is there a way to fix or reinforce stripped threads in a case like this? Should I be looking at thread repair inserts, epoxy, custom re-tapping, or even some kind of set-screw mod to secure the knob more reliably while keeping it removable?
Appreciate any ideas — I’d really like to salvage this setup if possible without scrapping the whole thing.
Thanks in advance!
Thanks in advance!
