First oil change lab report
Including Spyders & GT4s
PBP718
Has thanked: 32 times
Been thanked: 7 times
What does everyone think?
2024 Cayman GTS 4.0
Spokayman
Has thanked: 10 times
Been thanked: 11 times
It would help to know what car, what engine, what kind of driving, what brand and weight of oil, etc, etc.
Otherwise copper looks a bit high (weirdly my last test from my 944 showed the same).
‘85.5 944 Coupe-Alpine White/Burgundy
‘13 Boxster S-Guards Red/Tan
Former:
’83 944 Coupe
‘84 944 Coupe
’90 944S2 Cabrio
’95 968 Cabrio
’95 993 Carrera Coupe
01 996 Carrera 4 Cabrio
‘06 987.1 Cayman S
‘09 987.2 Boxster
PBP718
Spokayman wrote: Mon May 05, 2025 1:14 am It would help to know what car, what engine, what kind of driving, what brand and weight of oil, etc, etc.
Thanks, I realized I never added my car to my signature, so fixed now!
2024 Cayman GTS 4.0 and I'm not sure what oil it came with but I'm guessing the C40 version of 0W-40 Mobil 1.
2024 Cayman GTS 4.0
Spokayman
You didn’t note the miles on the engine, but new engines can give off higher levels of wear metals from bearings, pistons, camshafts, crankshaft, etc as they “break in”. I believe copper is often associated with bearings.
If this is a newer engine I don’t think I’d be too concerned unless the metals got worse, and I would look for them to decrease in subsequent tests as miles accumulate.
That’s my take, but I too would like to hear other (more informed) opinions from those in the know.
Former:
’83 944 Coupe
‘84 944 Coupe
’90 944S2 Cabrio
’95 968 Cabrio
‘06 987.1 Cayman S
‘09 987.2 Boxster
Spokayman wrote: Mon May 05, 2025 7:35 pm You didn’t note the miles on the engine, but new engines can give off higher levels of wear metals from bearings, pistons, camshafts, crankshaft, etc as they “break in”. I believe copper is often associated with bearings.
That was my general thought too, but I am not all that well informed on the topic. When I had the oil changed after 2k miles in my 992, the tech fanned open the oil filter and it was full of glitter. He knew it was going to look like that so did it to freak me out a little... He said it was totally normal for a first oil change, for what that's worth.
PBP718
I didn't because it's in the report right at the top.
2024 Cayman GTS 4.0
Goof
Been thanked: 12 times
PBP718 wrote: Sun May 04, 2025 1:23 pm What does everyone think?
Inline with expectations considering the engine had to be run-in. If anything, less iron than I'd expect.
Current: 2025 Porsche 718 Spyder RS, 2014 Mercedes-Benz C63 AMG Coupe Edition 507
