I have a 2022 Cayman GTS. My rear tires are at 5/32” tread depth. The dealership recommends tire replacement but my tire shop, where I’ve been going to for 40 years, says that I have “plenty of tread left.”
What tread depth do you replace your tires?
5/32”
4”32”
3/32”
2/32”
When the tread is even with the wear bar
Thanks,
Larry
Tire Replacement - What Tread Depth?
- Been thanked: 4016 times
In California, the minimum legal tread depth in front (steering axle) is 4/32". In the rear, it's 2/32" for the major grooves and 1/32" for others. You could probably get away with driving a little more, but the dealer is probably right as a technical matter -- assuming (if!) those measurements are accurate...
I leased a 2011 BMW to commute in back in the day -- about 500 miles a week to SF every day. I was determined not to buy new tires that I'd just need to turn in at the end of the lease. At about 72k miles, while on the highway, my right rear tire finally had enough and ripped clear off the rim. It was a downhill sweeper of a turn, and the weight was on the other side, so I became aware of it only because I saw the tire passing me on the inside lane.
- Stormy_Monday
- Has thanked: 349 times
- Been thanked: 456 times
I use the wear bars on the tire as my guide.
Red Cars Rule
2022 718 Boxster GTS 4.0
2025 Cayenne e-Hybrid
2015 Ferrari California T
- Has thanked: 3304 times
- Been thanked: 942 times
For street driven cars Stormy Monday's guide is the simplest as wear bars are 2/32nds and is the standard recommendation by almost all tire manufacturers. Now, toss that out the window for those of us that track our cars, because many of us have tires with that or less for Time Trials , HPDEs, etc.
Heck, a set of Hoosier A7 or R7s simply have sets of little grooves that probably aren't that deep brand new, ha!!
You don't say what tires you have. Some performance tires have 5/32 when new. I suggest you check the manufacturer's website to know that dimensions and recommendations for your tires. Some tires also have varying tread depths, and quick/random measurements can be unreliable.
Also consider that being 'close' to worn out is vague, and maybe not as close as it seems. A mere 1/32" can deliver many miles.
ReidMcT
The Hills, Texas
'21 Cayman T M6
'17 Boxster S PDK
The Hills, Texas
'21 Cayman T M6
'17 Boxster S PDK
- Arne2
- Has thanked: 10 times
- Been thanked: 218 times
How often do you drive on wet roads? If they are wearing evenly, for dry use only I'd run them to 2/32 with no qualms. If you drive in the wet much, I'd probably go with 3 or 4/32nds as my limit.
But make sure you look close at the inside edge. That's hard to see on these cars, yet is generally where they wear the fastest. You could have 5/32 across most of the tire and only 3/32 or less on the inside shoulder. Find the area and tire with the most wear and use that as your replacement canary.
- Arne
Past Porsches:
Past Porsches:
- 1972 911T coupe, silver
- 1973 914 2.0, Saturn Yellow
- 1984 944, silver
LA is probably very similar to the Bay Area in that we're pretty much done with the rain for a while. At this point in the year I wouldn't hesitate to run tires all the way down to the wear bars (or even a bit lower). Once the rainy season comes around again, it's a different story.
