1989 944s2 Brake Rotors
Posted: Fri Feb 14, 2025 3:13 am
by djtalon
Does the 944s2 have different brakes in the front? I ordered front rotors from autohauz and the ones recieved the offset and diameter is different.
Re: 1989 944s2 Brake Rotors
Posted: Fri Feb 14, 2025 3:36 am
by djtalon
From window sticker its pretty standard s2
Posted: Mon Aug 04, 2025 3:08 am
by Harold
Hey everyone,
I drive a 944S2 and recently ordered front rotors from Autohauz. When they arrived, I noticed the offset and diameter seem different from what’s currently on the car. Did Porsche use different front brakes across S2 models or production years? Just trying to figure out if I received the wrong part or if there's more than one spec for these brakes. Appreciate any insight!
Posted: Mon Aug 04, 2025 8:03 am
by tachbounce
Harold, the S2s (At least in 1989) have two different options.
Standard (NON-M030)
https://www.fcpeuro.com/products/porsch ... 5135104102
299mm front rotors
and
M030.
Left
https://www.fcpeuro.com/products/porsch ... 2835104360
Right
https://www.fcpeuro.com/products/porsch ... 2835104460
304mm front rotors.
Which part numbers did you order?
Most of the big euro autoparts sites just order in from Wholesalers such as SSF, WorldPac and Parts Authority. M030 rotors are sided and sometimes only sold in pairs.
Hope that helps,
Sean
