944 Speedometer Needle Shaft Repair
I came up with a DIY way to fix a broken speedometer needle shaft yesterday and thought I'd share. When changing the odometer gear or otherwise disassembling the speedometer, the first step is usually to pull the needle off the little splined spindle it sits on. Sometimes, when doing that, rather than pulling the needle off the shaft/spindle, the shaft breaks off. It's about the diameter of a small sewing needle and seemingly brittle, with no practical way to put it back together -- so at that point most people just start looking for a replacement speedometer. Here's how I fixed my spare speedometer...
Below: Normally, on a good speedometer the needle spindle sits in a nylon bushing that screw into the clear plastic frame under the white odometer carrier. The bushing serves to center the spindle, since it is attached to a loose/wobbly electro-spring set up below. As an aside, that bushing all but confirms the overall shaft is an assembly of pieces pressed together. There would be no way to get the nylon bushing on the thin part of the shaft otherwise. However, when the shaft breaks, that nylon piece can just be unscrewed by hand and removed to room to make the repair.
Below: the needle's shaft starts out as maybe 2.5mm in diameter, but then transitions to a very fine shaft about the size of a sewing needle. This is where the shaft typically break. Mine broke very close to the thicker base shaft, which seems common. The nylon bushing has already been removed so you can see the break and get to it.
Below: I discovered these 'telescoping' rods the other day at an Ace Hardware store. The kit shown includes a number of copper rods, each just small enough to fit in the next bigger rod.
Below: By pure luck, the 1/16" rod has an inside diameter that fits over the broken speedometer shaft almost perfectly. I cut a tiny piece off, equal to the length of the stub left on the needle, and put it on the stub. With a soldering iron, I heated up the copper/needle combo on the very end and let a small amount of solder wick into the tube to secure it onto the stub. It's important, ultimately, to get the tube straight on the broken shaft, but you have to do the final straightening later, as described below. There is vey little play between the tube and the shaft, but just enough that the tube can be ever so slightly crooked.
Below: Again by pure luck, the 3/32" tube fits almost perfectly over the thicker base of the diameter shaft. So I cut a length of it off and slid it over the broken shaft. I found it easiest just to cut it long enough so that it bottoms out on the lower end and sticks out on top just long enough for the other copper piece on the needle to slide all the way in. This way, when you slide the broken needle into the 3/32" tube, the height of the needle will be correct. Making the tube longer like this also makes it easier to solder in place and helps ensure the tube is straight. This time, I took a small length of solder and dropped it into the tube, then heated up the tube until the solder melted and wicked own and around the broken shaft, securing the 3/32" tube to the broken shaft.
Below: Then I melted a bit of solder on the outside of the 1/16" tube on the broken needle and heated up the 3/32" receiver tube until it melted the solder already on the smaller tube, allowing it to slide in and solder itself in place. Forgot to get a pic of that before putting the odometer carrier on, but you can see the tubes assembled below. Now is the time to ensure the assembled shaft spins straight, with no noticeable wobble in the shaft as it turns. You can turn the little splined hub clockwise and watch it rotate back. The hub should rotate around its axis without little to no wobble / run out. I ended up straightening mine with brute determination -- i.e., I'd melt the solder and try to hold the hub straight with an awl until the solder cooled, then tested, then did that another 50 times until I got it just right. :shifty:
Below: At this point the shaft is stronger than new, and the speedometer functions again. However, without the nylon bushing keeping the shaft on center, the needle is a bit wobbly. To fix that, I 3D-printed a 2-piece busing that fits in the recess above the shaft. I made it in two pieces, like valve spring retainers, so that they could hug the 3/32" tube. [Edit: see post 5 below for an improved approach.] Had to take care to make sure that was sized 'just' right, and smooth inside so that the speedometer would not hang up on it. These bushings get trapped in place by the faceplate, once it is screwed back on. With that, I now have a functioning speedometer! I compared this speedometer, as repaired, to a known good speedometer on my bench tester and they both read the same MPH at any given input rate, so it seems the repair does not alter the accuracy of the gauge. :)
Crazy Eddie
Has thanked: 213 times
Been thanked: 78 times
Awesome 👏
gb951
Has thanked: 29 times
Been thanked: 39 times
Excellent DIY.
gb951 wrote: Sun Jan 05, 2025 6:52 amExcellent DIY.
Thanks, it's better than throwing away a speedometer. On the bench, I'm still working to make it as smooth as a factory gauge. It sweeps fine, but the needle is ocassionally a bit sticky with very tiny changes in speed, at least on the bench. It's super important to get the spindle perfectly straight (no run out) to help with the stickiness. The spindle has close to zero torque, so any friction between shaft and the body of the speedometer and/or centering bushing can impede rotation. It may be a moot point in a moving car, however, as the constant vibration will likely prevent that from happening. With the original set up, the tiny little spindle goes through a nylon bushing, resulting in virtually no friction. With the bigger copper tubes, there is more surface area and therefore more friction, but I'm still working on that. :) In the meantime, this does work and my obsession with getting it perfect on the bench is probably academic in the real world.
I also had a weird thing happen where the speedometer started intermittently pegging itself at 160mph. How on earth can that be related to a broken spindle? Well, long story short, it wasn't. I guess all the handling aggravated a broken solder joint on the speedometers PCB. See pic below. At least it wasn't hard to spot. I re-soldered that and it was all good as new. :)
Well fast-forward a few days and I'm happy to report I was able to get the speedometer factory smooth, with no sticking, etc. I ended up changing my 3D-printed centering bushing so that it can ride on the smooth shaft under the splined hub. That section is a smaller diameter than the copper tube I was using before, so less over all friction. On close inspection, it's also hard to keep the copper tube 100% free of solder, and even the tiniest spec of it cause the shaft to hang up in the bushing. The other thing I did was "polish" the hub, as shown below, after realizing it had lots of tiny surface imperfections that could reduce the overall smoothness of the speedometer. The combined effect is a repaired speedometer that performs as good as new!
Below: here's the little area the new bushing rides on, which needs to be as smooth as possible.
Below: note the slight taper on the top end of the bushing. This ensures the actual contact point between the shaft and the bushing is a single point with very little friction. I'll post the STL in the 3Dprint section for anyone who wants to give this a try.
speedo busing render.jpg (86.54 KiB) Viewed 2867 times
Below: here's the bushing installed. The faceplate keeps it secured in place. Black is probably a better choice of colors now that it sticks out out beyond the faceplate, although the needle pretty much hides it from view either way.
944er
Has thanked: 14 times
Been thanked: 64 times
Any particular reason you did not come straight up with the larger hole and drop the diameter at the end? It would provide greater clearance for any shaft irregularities.
speedo busing rendeR2.jpg (104.96 KiB) Viewed 2831 times
944er wrote: Tue Jan 07, 2025 7:56 am Any particular reason you did not come straight up with the larger hole and drop the diameter at the end? It would provide greater clearance for any shaft irregularities.
That could work too. I really was just going on trial and error. I think this was version 27.... :crazy: These are tiny little things to 3D print, so part of the taper was just was printing practicality. The printer deals with the taper better than a chamfer when the chamfer is so small. The key is getting the hub true and straight. The more out of round it is, the more pressure it will exert on the bushing and the more likely to stick, so if it needs more clearance lower in the bushing, it's more likely to stick.
944er
Only 27? You're way better at 3d printing than me. ;)
944er wrote: Tue Jan 07, 2025 8:48 am Only 27? You're way better at 3d printing than me. ;)
:lol: :lol: It was mostly just trying different ideas for supporting the shaft without snag-inducing restrictions. The ah-ha moment was when I gave up on having the copper tube run in the bushing and moved up to that smooth section of the hub. By the way, I've since discovered you can get the same tubes in aluminum, which is lighter, so would probably use that instead going forward....
944er
With aluminum you would use adhesives instead of soldering. Too late for your fix, but it might also be possible to support the shaft on the lower section (between the break and the electro-spring) with a screw in bushing with a recess for the overlapping tube that will be glued on to the lower shaft.
