I was noticing when on a ertain part of Club Motorsports track (coming out of T5), that when I changed up from 2nd to 3rd quickly, I would occasionally get the clutch "balking" as if it did not want to really bite (as apposed to slipping). Didn't happen all the time. Talking to a BMW mechanic friend of mine, he said that later BMWs have a "blow back" valve that will restrict the flow of fluid under certain situations (ie; trying to do burn outs by repeated dropping clutch).
Does anyone know if the (981 GT4 has this "blow back" valve fitted?
Thanks,
Nick
Clutch blow by valve
- J-Dub
- Has thanked: 658 times
- Been thanked: 568 times
The 718 does have this valve, it is a plug with a hole in it to restrict the flow of the clutch fluid. Think of it like the restrictor on a low flow shower head.
On my 718 it is in the slave cylinder where the clutch line connects. Simply disconnect the clutch line and use a small screw to pull out the restriction. Will require bleeding the clutch though.
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
2004 VW R32
