944 Rear Hatch Switch Surround and Motor Arm
markagsmith5
Has thanked: 9 times
Been thanked: 30 times
Rear hatch switch surround
HatchSwitchSurround.stl
Rear hatch motor to cable arm
HatchReleaseMotor2Cable.stl
I found it necessary to run a 6 mm drill through the 2 holes, then with the motor removed from the car, attach the arm and tighten the holding nut. This forces the arm onto the spline and makes it easier to fit once the motor is back in the car.
1987 944 Turbo
2024 BYD Seal Premium
Has thanked: 526 times
Been thanked: 270 times
I don't need one but its reassuring to know its there if/when the time comes for one.
Thank you
