Turbo blanket to reduce engine bay heat
MoeMonney
Has thanked: 4 times
Been thanked: 38 times
I came across these turbo blankets, It seams they dramatically reduce heat in the engine bay and I was thinking of buying one for my turbo. Has anyone tried this and is it worth it?
Been thanked: 4078 times
I've seen folks use similar jackets, and wrap the headers, on a 951. I've just never been sure it's worth it. Even though the materials are presumably flame proof, they can soak up and/or trap fluid leaks and general grunge, which could result in fires. This probably isn't a popular opinion, but unless you have some need for extra heat shielding, it seems like a solution in search of a problem to me. Just my two cents. :)
And if you do need extra heat shielding for some reason, a metal shield would get my vote.
944m3
Has thanked: 25 times
Been thanked: 100 times
No doubt they work, but I’ve always wandered what that extra heat remaining under the blanket does to the turbo itself. Could be perfectly fine, but interested to hear any experience.
Has thanked: 526 times
Been thanked: 270 times
My understanding is the heat kept in the turbo housing over time can cause micro cracking due to the metallurgic characteristics of the housing. You might keep the total underhood heat down, but, long term, it negatively impacts the turbo itself.
michaelmount123
Has thanked: 31 times
Been thanked: 182 times
I've seen header wrap cause exhaust headers to crack due to heat retention. I think Tom provided a great response (above).
Jotronic
Has thanked: 58 times
Been thanked: 32 times
Charlie at Evergreen told me to absolutely NOT use a turbo blanket on my RaptorX as it would damage the turbo.
aboyandhisdog
Has thanked: 136 times
Been thanked: 57 times
I wonder if, as a general rule, it makes some sense to insulated some things that are affected by other sources of high heat, but to not try to insulate the source of the heat itself? High heat sources need good air circulation to cool. I do like the idea of strategically placed heat shields to move or deflect hot air out of the area where it is not wanted.
-Tom
Fort Collins, Colorado
Porsches past: 1970 911T, 1971 911E
Porsches present: 2006 997 C2
Porsches in the future: Nope...keeping the '06 to the end!
944m3
That’s my strategy, protect the sensitive stuff from heat. So many good materials now on the market, for example heat reflective gold tape to wrap around things that are near heat.
Uwon
Has thanked: 9 times
Been thanked: 7 times
Turbos heat up because the process of compressing air quickly creates allot of heat. Hot compressed air is less dense ( I.e. less oxygen). The reason most high output turbos are accompanied with an intercooler is to cool down the compressed air and therefore yielding additional oxygen to mix with the fuel. More oxygen means that more fuel can be added yielding more power.
The blanket in question will retain additional heat in the turbo and hence the compressed air robbing some power because now all the heat has to dissipate through the hotter compressed air being fed into the motor intake whether or not an intercooler is present.
The more efficient way to deal with heat from the turbo is by deflecting heat with heat shields and/or directional aids near but not to close to the turbo to maximize air circulation.
Additionally, the blanket in question will create much unwanted heat inside the turbo that would yield a shorter lifespan to the turbo bearings (burnt oil) and perhaps even the impeller.
M2CW
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
MoeMonney
Heres a great engineering review of turbo blankets which shows a performance improvement. Faster spool up and more power. Just with a blanket.
