I had a thought, would it be a good idea to run square or x type Orings rather than the factory one. My thought process is they should have more sealing surface and a material like viton should shrink less overtime saving one from having to redo the aos seals.
Interested to hear other thoughts
thanks
AOS Seals
- Been thanked: 4078 times
Knock on wood, I've never had any leaks with the factory AOS o-rings.
