718 Life: Gone With The Winds(shield)?
lukesward
Has thanked: 40 times
Been thanked: 251 times
718life.blogspot.com
Big day today.
'Big'.
It's all relative. This afternoon I'm tackling the small (tiny) windshield 'bruises' on my GTS.
The first one I picked up a scant 150 kms into ownership, in Germany, the other on the drive back from picking up the car in London, Ontario. One on each side, driver and passenger. Both a very similar pattern, in that there are actually three little marks to each of them. Presumably when the rock struck the window the first time it rolled and struck it a second and third times, creating smaller divots. In each case. So, six impact points. Ugh.
Fortunately I guess, neither set have resulted in anything other than some gouging out of the glass at the surface. No deeper chip, or 'bullseye' and definitely no cracks. So, lucky there, as replacing a whole windshield is not really something I want to do. I mean, come on! The car's barely a year old!
Cue the Internet, and the wonder that is YouTube, where I can ply my way through countless windshield repair videos. This has resulted in me feeling fairly confident that I can use the final step of the most common repair process for deeper chips and cracks, to effectively fill the little gouges, and with luck, diminish them significantly.
I start with the passenger side, as my 'tester'. It's the larger of the two impacts and below an adult's eyeline for the most part. I use the resin from the Permatex kit (12$ from Amazon) and followed the instructions for the final step of a chip repair. No creation of vacuum and injection of resin needed, just the wipe with the resin to fill the indent, the curing strip and sunlight, and then the razor blade to scrape off the excess.
A bit nervy at first, I'll admit, but I take the plunge and proceed. It's easy enough, and the resin cures quickly in the sun. Scraping off the excess (carefully!) with the razor blade turns out to be simple and then it's time for a closer look.
So what's the verdict?
In a word:
Meh.
Visually, perhaps, it's a touch smoother to look at, a bit diminished...maybe...5 percent? Hard to tell, but not much, I feel. The little scuff mark is gone, but not the 'bruises'. Certainly hasn't made them disappear. I'm underwhelmed. Tomorrow I shall have a closer look while driving and see if it has made a noticeable difference from the cockpit. In the meantime, I'll go ahead and treat the driver's side while I have some resin left and since it turns out to not be as daunting as I thought.
Ah well, they can't all work out perfectly can they?
Maybe I'll try another pass at it sometime...
~ Luke
Oh and the Boxster too, right!!
~ Luke
Pachanga718
Has thanked: 236 times
Been thanked: 127 times
Looks a little better. Glancing blows on windshields are tough as they are like a gouge. Almost better if it was a crack that could be filled.
I was getting my wife's car windshield replaced (in the CO we have heinous rocks on the road and a lot of them) and was speaking with the owner of the shop. He runs a windshield PPT protection on his R8. It costs ~$600 (but then again he owns the shop).
Anyone here put that on their C or B ?
Has thanked: 4451 times
Been thanked: 2417 times
Pachanga718 wrote: Wed Jul 31, 2024 8:29 am Looks a little better.
I haven't talked to anyone who has had it added so not sure how good or bad film on the w'shield might be. It would protect but does it distort views, especially in varying conditions - night, rain, glare, extreme cold, etc? Would it streak and/or scratch easily w/windshield wipers, especially if any dirt or hard particles were present and got embedded? (Pro and other racers, especially endurance, use plastic film tear-offs but that's mostly to simplify and save time at pit stops.)
PPF on windshields was mentioned by a couple of us last August but there was never any further feedback from anyone who had installed it on their car. I'd be most curious about wear and what it looks like after a time. If you do add it, please give feedback! :thumbup:
https://www.carpokes.com/viewtopic.php? ... =10#p22130
Pachanga718
blueline wrote: Wed Jul 31, 2024 8:43 am
Good points and my questions too. If I do it, I would need to meet with him and see his R8 install first.
Will do. Still deciding. A new OEM windshield is about $700 - $800 quickly looking at places like Suncoast, a bit of a toss up.
