993 Used Starter and mass air flow sensor for sale
Post things for sale here!
Rusty Rotors
I have a used starter and mass air flow sensor for sale from my 1996 standard trans 993. I replaced both units when I had the engine/trans removed to replace the clutch. Nothing wrong with either of them. Just replaced them because it was easy to do while I had it removed. Approx 60k miles on them.
email for pictures if needed. (I did not know how to attach to the ad)
2023 Macan T
2007 997 Carrera S Cabriolet
Has thanked: 4518 times
Been thanked: 2451 times
Rusty Rotors wrote: Tue Jul 09, 2024 12:37 pm I have a used starter and mass air flow sensor for sale from my 1996 standard trans 993. I replaced both units when I had the engine/trans removed to replace the clutch. Nothing wrong with either of them. Just replaced them because it was easy to do while I had it removed. Approx 60k miles on them.
Tom's guide for posting pictures. It's straightforward. :thumbup:
If your ad is not already in a common image-type format with a file extension such as JPG, JPEG, PNG, etc you could try saving the ad as one of those files or saving as a PDF file which can be posted to Carpokes the same way as photos.
