Current draw 1990 S2
CEW
Has thanked: 4 times
Been thanked: 23 times
If the car sits for a week, it starts kinda slow and I lose my radio presets.
Current draw is around 90mA with all fuses in place. When I remove fuse #8 (central locking) it goes down to around 26mA. Is my central locking module shorted inside? Or what could be causing this?
Thanks.
Been thanked: 4016 times
CEW wrote: Tue May 07, 2024 9:32 am If the car sits for a week, it starts kinda slow and I lose my radio presets.
Thanks.
Does your central locking work ok? All locks functional? I'm not sure what it is supposed to draw, but 90mA is pretty high overall. Anything else on that fuse?
CEW
Central locking works ok but not perfect. The drivers door lock actuator does not lock/unlock. The console switch works and operating the drivers door lock with the key will actuate the passenger lock and turn the blinking red lights on both lock knobs on.
The “relay sun roof” is also on that fuse. No problems with the sunroof operation.
icb
Has thanked: 59 times
Been thanked: 54 times
Have you made any progress with this?
How are you measuring the current draw?
Ian Borg
1988 Porsche 944S
CEW
No further progress yet…no time to dig into it.
Im using a digital vom and measuring mA in series between the neg battery cable and neg post.
