all-new Cayman GT4RS... what yall think?
edirtaynine
Has thanked: 16 times
Been thanked: 6 times
i think the car is absolutely gorgeous. Starting around $141k, that's awfully close to GT3 territory though...
i love my 911 and all 911's but i personally think the mid-engine setup lends itself to a much better visual design of the car and driving feel. The 911 is amazing no doubt, but i think if porsche swapped in all the engineering and tech into the cayman, it would be the better car... which they wont allow haha
991.1 C2S
Has thanked: 962 times
edirtaynine wrote: Wed Nov 17, 2021 4:18 pm i think the car is absolutely gorgeous. Starting around $141k, that's awfully close to GT3 territory though...
The motor is from the GT3 (not 718) so they didn't hold back too much. And a 7:04+ 'ring time is bonkers and faster than a whole lot of really fast cars. The new GT3 gets around the ring faster still, which Preuninger tries to explain in this R&T article:
https://www.roadandtrack.com/news/a3826 ... rburgring/
“With the GT3, we tried very hard and put everything on it we could,” Preuninger said. “It has rear-axle steering. This car doesn’t—it’s a mid-engine car, so it doesn’t need it, but it would surely make up a second or two or three.” Preuninger also pointed out the GT3’s double-wishbone front suspension, which the GT4 RS doesn’t get. Another factor: the GT3’s electronic limited-slip differential. “We don’t have the space [in the GT4 RS] for the hydraulic power pack for an electric diff, so we had to go with a mechanical diff.”
Preuninger also notes that the 911 GT3 makes more downforce than the Cayman GT4 RS, and the rear-engine car has room for wider tires. “It’s not only the engine [that makes you] quick on the Ring, it’s the rest of the car as well,” he said."
At any rate, the car is still mighty tempting. The $141k base sounds good too, but it can get well into GT3 price territory fast if outfitted like the press car. I played around with the configurator and got over $200k by loading up on options, though $160k or so would get you a nicely spec'd car...
gr4rs pricing.jpeg (525.87 KiB) Viewed 1227 times
edub
Has thanked: 2 times
Been thanked: 16 times
It's very interesting because it solves the silly problem of putting the engine on the wrong side of the rear axle.
Supposedly it has heim joints and a loud intake which makes me just want to spend the money on a race car instead. It would be cheaper.
I am very jealous of the improved gearing though. If a GT4 remains my last ICE car, I will absolutely be looking to swap the gears out just so I can row them more in the hills.
