Normal Drive settings options
Posted: Fri Mar 01, 2024 2:25 pm
by 7gears
The Normal Drive settings in the vehicle settings options on the dash of my 2023 GTS allow you to select different options, such as disabling the ASS, enabling sport exhaust and others, but it resets when the car is turned off. Is there a way to save these settings permanently?
Re: Normal Drive settings options
Posted: Fri Mar 01, 2024 2:40 pm
by 71eh
7gears wrote: Fri Mar 01, 2024 2:25 pm
Hey. You have to save them under the "individual setting"... If I understand you correct, if you change any setting while in the "Normal" mode, it will always default back to factory when restarted.
If you save them under "Individual", they will (should be saved).
Some people have reported issues that their 718 does not save their settings in individual mode. Some people have also had to have the dealer reset the software.
But try to Individual setting, and come back and let us know if that works
Posted: Fri Mar 01, 2024 2:48 pm
by 7gears
Thanks! I’ll try the individual setting suggestion. It should work.
Posted: Fri Mar 01, 2024 3:45 pm
7gears wrote: Fri Mar 01, 2024 2:48 pm
Aaaaaand, welcome to Carpokes!!!
