Can’t set charging for 85% - it always hits 100%?
KCG_981_Taycan
I have a 2023 GTS ST and I have a ChargePoint charger. The utility company prefers the Chatgepoint to work from midnight to 6 am. By setting the Profile to 12:15 am to 6 am, the car will charge overnight. See attached screen shots from MyPorsche app. The timer shows 85%. But the car still charges up to 100%. What setting am I missing to have it stop at 85%?
- IMG_6866.png (134.56 KiB) Viewed 15630 times
- IMG_6867.png (140.53 KiB) Viewed 15630 times
- toddinmd
- Has thanked: 31 times
- Been thanked: 59 times
I have a chargepoint and have been using it without issue for the last two years. Your issue is with your timer and profile. The way to fix it is to, disable the timer and set the profile minimum charge to be 85%. That will fix it. Porsche does not make it clear how the two options work.
I only use the timer when I'm planning a long trip that I want the car to be at 100%.
2018 991.2 GT3
2022 Taycan CT4
2018 991.2 GT3
2022 Taycan CT4
julianm
- Has thanked: 14 times
- Been thanked: 6 times
Your 6am Timer is turned Off in this screenshot, if you didn’t notice.KCG_981_Taycan wrote: Wed Feb 07, 2024 1:29 pm I have a 2023 GTS ST and I have a ChargePoint charger. The utility company prefers the Chatgepoint to work from midnight to 6 am. By setting the Profile to 12:15 am to 6 am, the car will charge overnight. See attached screen shots from MyPorsche app. The timer shows 85%. But the car still charges up to 100%. What setting am I missing to have it stop at 85%?
2023 718 Boxster GTS 4.0
- Rich_911
- Has thanked: 2 times
- Been thanked: 42 times
I don't mean to hijack this thread, but charging my 2020 Taycan-Turbo is a bit of a mystery. I've always charged to 85%, and when the car was new this routinely gave me 246 miles. I've been diligent with the battery recalls, service, and software updates. Now, when charging to 85% I'm only getting 191 miles - that's a loss of over 50 miles. Has anyone else experienced this?
Regards,
Rich
2008 911 4s
2020 Taycan Turbo S
Rich
2008 911 4s
2020 Taycan Turbo S
