Aos water line flush
Removed airbox and noticed the connecter that connects the water line to the AOS became brittle and broke. I think pieces of the connecter dropped into the lower line. Clamps for this line look like a 'one-and-done' type; can't figure out how to open them. If I briefly start the car, will this flush the line?
- Been thanked: 4025 times
Having a hard time following what water line you are having problems with. Can you post a picture?
Thanks for confirming the clamps. Haven't run across that before. Have aluminum connector on the way. My concern is pieces of the old plastic connector are down in the hose and I would like to flush them out before reconnecting. Realizing there would be a coolant loss, can I start the car to run coolant out of and flush the disconnected hose?
