996 sloppy shifter
Posted: Wed Sep 20, 2023 6:39 pm
by Tom_N
I recently bought a 2004 911 40 Jahre. It now has 80k miles. Compared to my last car, a S2000 that had a very snappy shifter, the 911 is plain sloppy. Without resorting to a shift kit is there anything like bushings or cable adjustments that can improve the stock item?
Re: 996 sloppy shifter
Posted: Wed Sep 20, 2023 8:12 pm
Tom_N wrote: Wed Sep 20, 2023 6:39 pm I recently bought a 2004 911 40 Jahre. It now has 80k miles. Compared to my last car, a S2000 that had a very snappy shifter, the 911 is plain sloppy. Without resorting to a shift kit is there anything like bushings or cable adjustments that can improve the stock item?
Have you driven another 996's to compare? I'm wondering if you were just spoiled by the S2000 shifter, which I've heard is about as good as it gets....
Posted: Thu Sep 21, 2023 4:03 am
by 996C438
The 996 uses plastic bushings which get sloppy with age . There are many aftermarket vendors that offer upgrades . I have a 99 996 C4 with 150k . The shifter when I bought it was as sloppy as a crack whore .
I installed the Function First shift kit . It is considered one of the better kits out there . All metal and real bearings . Not hard to install . Shifter movement is now butter smooth . It is not a short shifter so the throws are the same .
Just my opinion but when everything is perfect with the 996 it still won't be as good as the Honda . For a variety of reasons . But it can be greatly improved . This is the kit I installed .
https://www.function-first.com/products ... t-solution
Posted: Thu Sep 21, 2023 4:16 am
by msmmiami
Had same issue and installed a 997 shift console. $330 @ Sunset Parts. It's a bit tighter of a shift and some aren't crazy about it but I'm totally happy with it.
Posted: Sun Sep 24, 2023 1:59 pm
by Tom_N
Tom wrote: Wed Sep 20, 2023 8:12 pm
No, I haven't had the chance.
Posted: Sun Sep 24, 2023 2:04 pm
by Tom_N
I'd like to avoid the cost of a shift kit for now if OEM bushings would give some improvement. Anybody had experience with them?
