992 Break in procedure
RBM_911
Has thanked: 5 times
Been thanked: 6 times
We are picking up our 2024 C4S on Saturday and I'm reading up on the break in procedure. Seems to be a hotly debated topic on some forums...
The manual seems fairly clear:
The moving parts of a new vehicle must be run in. The parts require the first 1,875 miles (3,000 km ) for this purpose. The oil and fuel consumption may be somewhat higher than normal during this period.
During the running-in period, drive as follows:
Preferably take long trips. Avoid frequent cold starts with short distances as much as possible.
Do not participate in motorsport events, sports driving training or similar events.
Avoid high engine speeds of 4,000 rpm or more. Drive at low engine speeds when the engine is cold.
I've read on other forums that this break in text only exists in the US manual and is not needed. Just get in the car and drive.
So I switched my VPN to Germany and the manual, while laid out a bit differently, has the same text. (hard to believe something on the internet was inaccurate! ;) )
Bei einem neuen Fahrzeug müssen sich die beweglichen Teile zunächst aufeinander einlaufen. Dazu benötigen die Teile die ersten 3.000 Kilometer. Der Öl- und der Kraftstoffverbrauch können in dieser Zeit über dem normalen Wert liegen.
In der Einfahrzeit wie folgt fahren:
Längere Fahrstrecken bevorzugen. Häufige Kaltstarts mit kurzen Strecken möglichst vermeiden.
Nicht an Motorsport-Veranstaltungen, Sportfahrschulen etc. teilnehmen.
Hohe Drehzahlen über 4.000 Umdrehungen pro Minute vermeiden. Bei kaltem Motor mit geringeren Drehzahlen fahren.
We are thinking this car is a keeper so I want to do it right. But, nearly 2000 miles under 4000 rpm seems like a loooong time.
Any thoughts on best approach from those with more knowledge or experience would be appreciated.
Has thanked: 4446 times
Been thanked: 2414 times
You're decision is the wise one, for sure! Definitely follow the manual.
There is a thread elsewhere on this subject that I'll hunt up. If/when I find it, I'll post the link here.
2,000 miles will go faster than you think and it will be soooo much fun. Take several back-country multi-hour drives and it will be there before you know it.
I will add that an occasional smooth, steady increase above 4k is fine here and there, just keep it mild (ie: 5k) and don't hold it for more than a couple of seconds What Porsche doesn't want is someone wringing out the motor in any manner. As always with break-ins, vary your rpms/speed as much as possible. Drive a bit erratically in that regard! :D
The cold start instructions and keeping rpms quite low when cold is maybe the most important. Use your gauges and watch the engine oil temps, not necessarily the coolant temps. Let the oil get to proper temp (or close) before doing anything that's not grandmotherly driving. (That's true after the car is properly broken in too.)
RBM_911
Thanks for the input. I always watch the oil temp and let it fully warm up before getting over 3500 rpm.
Any thoughts on an oil change after the 1875 miles? I know not required by Porsche but have read suggestions that it is worth doing for the long term.
RBM_911 wrote: Tue Aug 15, 2023 8:28 am Thanks for the input. I always watch the oil temp and let it fully warm up before getting over 3500 rpm.
I always do so. Maybe it's overkill, especially with the amazing qualities of today's synthetics, but even those can still carry contaminates even if the lubricant itself seemingly never breaks down.
Plus, I sleep better! :D
Has thanked: 935 times
Been thanked: 4006 times
I always follow the book too. Was surprised to learn the new GT4RS has a break-in period of just under 1k miles -- not sure if that's a fancy-motor thing or if Porsche might start moving to that number.
And great find on the German manual!! Love that. And to think people would type stuff on the Internet with thoroughly fact-checking first!
RBM_911
While there is part of me that suspects the specified break in is a bit of overkill there is a larger part that greatly values sleeping well at night :D
So drive like a grandma for 1875 miles, change the oil, then redline to 1876 it is.
RBM_911 wrote: Tue Aug 15, 2023 12:29 pm While there is part of me that suspects the specified break in is a bit of overkill there is a larger part that greatly values sleeping well at night :D
While breaking mine in, I very much got the sense it was overkill. Even Ferrari says you're good to go at 621 miles. Alas, pure superstition forced me to comply with the manual so as not to upset the Porsche gods and doom my car. :angel:
nvbirdman
Been thanked: 22 times
I tried to reply to this post a few days ago, but for some reason it didn't go through. We all know that putting break-in mileage on a new Porsche is a boring job that must be avoided at all costs. I now have a solution, you can thank me later. Just pay the teenager who mows your lawn to carefully drive your brand new Porsche enough to get past the break-in miles. If you would like more advice, just ask, I'm full of it.
nvbirdman wrote: Thu Aug 17, 2023 11:12 am I tried to reply to this post a few days ago, but for some reason it didn't go through. We all know that putting break-in mileage on a new Porsche is a boring job that must be avoided at all costs. I now have a solution, you can thank me later. Just pay the teenager who mows your lawn to carefully drive your brand new Porsche enough to get past the break-in miles. If you would like more advice, just ask, I'm full of it.
Lol. No doubt the "carefully" adverb applied to said teenager's driving instructions gets followed to the letter! :lol:
edit: But what a memory he'd have for life!! (Assuming both he and the car survived...)
RBM_911
While a very good idea, I believe I call that plan "B"... :lol:
