Does anyone know the part number for the coolant drain plug on the block of an '87 944 NA? I can't seem to locate it in the PET. At the moment I have an M8 x 16mm bolt with and aluminum washer in there. I'm at the end of my build and would like to have the correct part in there.
Thanks!
Coolant Drain Plug on Block?
Zirconocene
- Has thanked: 80 times
- Been thanked: 52 times
I think you're looking for PN 900 075 087 02, but even in PET it's just called out as a M8x16 bolt. The sealing ring is PN 900 123 105 30, 8x14.
I hope I'm not misleading you but it's hard to see what's going on, on that side of the engine in PET.
Good luck
Good luck
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
