911 Z-Block P207 Tool
Been thanked: 4017 times
Here are files for a 3D-Printed Z-block fixture, for the air-cooled 911 crowd. I’m posting two versions. The one named Zblock EZ, shown in Red below, can be assembled with regular hardware store parts. The other, shown in yellow, requires a heat-set brass insert from McMaster Carr. Both of these tools serve the purpose of the factory P207 tool, to adjust valves, set cam timing, measure piston to valve clearance, etc. These work with standard dial indicators with 3/8” mounting posts, and may need a short extension on the dial indicator.
The yellow one uses a short M4 x 0.7 heat-set brass thread insert, item number 94459A150 at McMaster-Carr. To install, put the insert on the tip of a soldering iron, then melt them into the hole on the side of the z-block. You can then use a standard M4 x 0.7 bolt to secure the dial indicator in the z-block. If desired, you can also buy an M4 thumb screw, or make one using the M4 thumbscrew 3D-Printer file posted below.
Zblock by Carpokes.stl
Zblock EZ by Carpokes.stl
M4 Thumb Screw.stl
justinwestrum
will try, thank you!
travasn2003
will try it...thank you!
ZIPPER-
Nice i will give both of them a try.
AUSTmike
Will give it a try thanks for the idea.
lubing20
Tom wrote: Sat Jun 17, 2023 1:23 pm Here are files for a 3D-Printed Z-block fixture, for the air-cooled 911 crowd. I’m posting two versions. The one named Zblock EZ, shown in Red below, can be assembled with regular hardware store parts. The other, shown in yellow, requires a heat-set brass insert from McMaster Carr. Both of these tools serve the purpose of the factory P207 tool, to adjust valves, set cam timing, measure piston to valve clearance, etc. These work with standard dial indicators with 3/8” mounting posts, and may need a short extension on the dial indicator.
M4 Thumb Screw.stl
excelent thank you
lubing20
thank you
jagger71
Great idea and thanks for sharing.
Anyone printing these and selling them?
Thanks
Rich
drich1029
Anyone printing these for resale yet ?
carbits
thanks for sharing
